1 - 5 of 5 Posts
Hi
My engines clunking when put into reverse and when u accelerate. I have replaced the upper mount with fluid in it already. Anywho. Yesterday I got the lower torque mount. I got the old one off car. And the new one is just a bit to big to go into its location. The old ones crack needs to be replaced. I checked the part number just in case dealer gave me wrong part...all the numbers match. I hope someone else has had this problem. I have a 12 ex 1.8l auto sedan.
You probably just need to pry open the space a bit for the new bushing to slide in.
There are a few write up/DIY on this site or YouTube.
2015 Honda Civic Si Coupe
Spray it with some kind of lube. Should slide right on in.
Yah well I figured out what the problem was. The part that came from dealer was the wrong one. So I would have never got it in it spot. Thank you all for the help. The part that came in the bag was for the crv. It was a 1/4 inch to big.
Glad you figured it out. you gotta have over 200K on that now.....
1 - 5 of 5 Posts
