1 - 3 of 3 Posts
Hello,
I have a 2014 Civic LX with original 195/65-15 6Jx15 ET45 steel rims. My neighbour is giving away his alloy wheels from a 2001 Honda Accord EX V6 (205/65-15 6.5Jx15 ET55) in near perfect condition.
PCD and center bore are the same. Will the offset be an issue? The tires are practically new winter tires.
Will the Accord wheel configuration as is right now fit in my civic?
If I don't use the tires and just the wheels, will the offset be an issue in either case?
Thanks!
Should fit fine. The higher offset will put the wheel closer to the strut by about 16mm. You may want to check your inner clearance to make sure you don't hit. Tires are about 2% bigger than stock and OK to use as well.
Will your neighbor let you test fit them to be sure?
He just wants them gone so I'll take them anyway. Thanks for the reply!
1 - 3 of 3 Posts
