1 - 20 of 40 Posts
Discussion Starter #1 (Edited by Moderator)
2014 Honda Civic Coupe/Sedan Bulb Reference List
So.... I couldn't find this or the information was so scattered when I searched. Here is what I came up with from taking my bulbs out/searching/reading my owner's manual.
2014 Honda Civic Coupe/Sedan Bulb List:
Exterior
High Beam: HB3/9005 60W
Low Beam: HB4/9006 51W
Fog Lights 1.8 L Model: H11 55W
Fog Lights 2.4 L Model (SI): H8 35W
Front Turn Signal/Parking/Side Marker: 7443 T20 28/8 W Amber
Brake/Taillight: 21/5 W
Rear Turn Signal Light: 992/7440A 21 W Amber
Rear Side Marker Light: LED
Back-up/Reverse Light: 921 16 W
Tailights: 7443 T20 3 CP
Rear License Plate: 194/168 T10 5W
High-Mount Brake Light 1.8 L Model: 7440 21 W
High-Mount Brake Light 2.4 L Model (SI): LED
Interior
Map Light: 194/168 T10 5W
Dome Light: 194/168 T10 8W
Trunk/Cargo Area: 194/168 T10 5W
It should apply to the 2013+ civic coupe also. I believe the only differing factor is the fog lights for the SI and non si civics (can somebody confirm?).
Fog Light Coupe
Non SI= H11 55w
SI= H11 55W
Fog Light Sedan
Non SI= H11 55w
SI= H8 35w
****if anything is inaccurate PLEASE LET ME KNOW****
Hope this helps!:thumb:
Edit by DWils: this information is currently up for debate and is in the process of being corrected. Please be patient and read through the entire thread before basing your purchasing decision on this information.
Discussion Starter #2
Updated with some correct information.
I hope this helps whoever buys LED's for their interior or needs a replacement bulb.
I know who U R.
Welcome to the 9th.^^^^ and thanks
Thanks and no problems!
thanks but do these apply to the 2014 civic coupe? exl
2014civic coupe
It should apply to the 2013+ civic coupe also. I believe the only differing is the fog lights for the SI and non si civics (can somebody confirm?).
Fog Light Coupe
Non SI= H11 55w
SI= ??????
Fog Light Sedan
Non SI= H11 55w
SI= H8 35w
Baned
Does anyone know how would HID Kit work for the highs due to the DRL's?
This question has been asked and answered tons of times. Search or browse around in the Lighting section of the forum and you'll find your answer and maybe some other options.
You are incorrect about the 2014 2.4L Si fog lamps, at least in the Coupe. They call for H11 55W bulbs (per owner's manual).
Also, 2014 2.4L Si Low beams for the Coupe are H11, 55W as well.
honda oval fog lights usually are h11, honda round fog lights usually are h8
both h11 & h8 are the exact same bulb, the difference is h11 is 55w, h8 is 35w
Hey guys sorry to ask here but I need some help and I know this is the perfect place to ask. I have a 35W 6000k Volt Hid kit in my 2012 civic Lx and was just wondering if this same kit would work on a 2014 EX sedan? This is the kit I have:
9006 / HB4 Volt HID Digital+ HID Kits
Hope you guys can help!
Just check your manual. It would only be the bulb you'd have to check everything else should just be plug n play.
PMM_FB2
This is wrong, the 2014/2015 reverse is a 921 bulb not a 7440. I found out the hard way. Also look at the socket. It says 921. I just lost $25.00 cause of this thread.
I had the same problem when I bought reverse LEDs for my 2014 si sedan I bought 7440 and they where to long and big had to send them back and buy 921, anybody know for sure what bulbs for the taillight brake light bulb, the center red parking lights and the turn signals? I'm wanting to buy new led red bulbs for all them and need to know for sure so I don't make the same mistake as I did before with the reverse, I need to know how how tall of bulbs I can fit as well
for the bulb size for the 2014 civic for the rear side marker light it says led is the kinda bulb it is as i recently tinted tail lights and they it overly dark so i was gonna put something brighter
1 - 20 of 40 Posts
