Okay one of my valves stems is broken, well I cant get any air in or out of the tire. All I need to replace is the valve stem? I’ve never replaces a valve stem on a car with tpms. Also, does anyone have a Honda part number? Thank you.
As stated in your other thread. 2014 does not have tpms sensors in the wheel.Okay one of my valves stems is broken, well I cant get any air in or out of the tire. All I need to replace is the valve stem? I’ve never replaces a valve stem on a car with tpms. Also, does anyone have a Honda part number? Thank you.
At the very least the top bead needs to be broken down to swap it out.As stated in your other thread. 2014 does not have tpms sensors in the wheel.
If you just need to replace the schrader valve, you can simply unscrew it and install a new one. If the whole stem needs replaced, then the tire will need to be removed/remounted.
2014 Schrader valves don’t have sensors. Just replace it with a generic one. If you can break the bead, you can replace it yourselfOkay so the schrader valve is connected to the sensor, and this is a universal part?
