1 - 7 of 7 Posts
Discussion Starter · #2 ·
shelglass the wheels are 17 inch you made a mistake so you know next time the Accord wheels are 17 inch
2015 Accord Sport Sedan has 18x8, and Accord coupe V6 EXL has 18x8 wheels.
I've got a 12 Civic LX sedan sitting on 2011-12 Accord V6 coupe 18x8 wheels. They are damn close to the struts in front, like 3mm clearance....but no problems in the 3 years they have been on it.
I'm not positive but I'd expect the offset to be the same between the '12 and '15 Accord wheels. Research would be required LOL
I'd bolt a bare wheel on to check clearances before making a commitment first!
My stock tires were 195-65-15,
Your EX should have 205-55-16 stock and are about the same overall diameter as the 15" above,
and I'm on 225-40-18 now. Damn close to the same diameter, speedo error is negligible like about 1%.
Lots of views anybody will the wheels 17 inch work?
They will work fine but the offset is 45mm for the Civic and 55mm for the Accord rims.
I'm using the 2013 Accord V6 17x7.5 wheels with Michelin 225/45R17 tires which are the same diameter as stock Civic and it handles great.
1 - 7 of 7 Posts
