1 - 1 of 1 Posts
Make / model: 2015 9th Gen Civic Crank Position Sensor CKP or Cam Sensor 1.8L
History:
175K miles from uber driving. Original owner. ALL STOCK NO Mods.
I will be doing repairs on my friends 2015 Civic. He has a couple of codes - I will [edit this post when I get the codes] My friend has already purchased non-oem Cam and Crank sensors.
Other than this problem the car was running fine.
Symptoms: Car will start but not stay running. Codes indicate crank position sensor or Cam sensor.
I'm highly experienced at repairs but did not find any youtube videos on this subject - possibly because 8th gen is the same? Last Honda I worked on was 2003 Civic EX.
I was going to unplug the Cranks sensor and see if the car starts but enters limp mode / won't run above 3,500 rpm. If yes then I will replace the Crank sensor. If no I will replace the cam sensor. I have a Hayes repair manual.
Any suggestions or links about how to proceed would be appreciated I searched this forum and look for videos on Youtube.
Thanks!
1 - 1 of 1 Posts
