41 - 58 of 58 Posts
· Registered
Write up done:
· Registered
Not really sure what that does, but it doesn't force the update. I tried it (accidentally) when I was fooling around and got the same thing, it doesn't seem to read the USB.
That said, a little gutsy to try to force the update since it could brick your HU. 😅
If you really want to brick it (I would try this, personally, unless I were planning on replacing the HU), I'm wondering if you could just use a hex editor and edit the model information located at the top of the update file. Again, just an idea that would be to highly likely result in a brick.
hi friend,
i have some unit of civic 2014 ex i can try with them, so let me now the steps for test jejeje
· Registered
Write up done:
is it possible to install 2014 civic Si head unit on Honda civic 2015 EX?
· Registered
My 2015 EX doesn’t have a subwoofer. Do you think the CRV head unit will still work?
I don't believe so. Possibly this unit
But it is listed as sold out there so you would need to find it somewhere else.
· Registered
Thanks Spelvin and others for your hard work, never thought I would see CarPlay while keeping OEM functions! Very exciting stuff.
I've recently updated the wiring in my 2012 Civic LX to the 2014 equivalent (still need steering wheel HFT controls, backup camera, and LaneWatch). I was able to install the CR-V unit (perfect fit with nav bezel!) and the CarPlay beta. However, every time I tap the CarPlay icon with my iPhone plugged into the arm rest USB port, I see this error:
493756
Works the same on my brother's 2013 Si that he upgraded to the 2014 wiring as well. USB port works fine otherwise for audio and other functions.
Hoping against hope that somebody somewhere knows something about this. I'm honestly willing to pay for info that gets CarPlay working, I want it that badly haha.
· Registered
Guys I too saw the CRV software update and I managed to get it to work on my 2016 HR-V. Also the radio from the CR-V is plug and play with our radios. So I went ahead bought me a radio from a 2015 CRV, bought the A/M radio face plate for my HR-V and got the software from some guy on ebay that sold it to me for $50 and plugged it in and did the update.
Hey, is this is the US or UK? I have a CRV 2015 and would Love Carplay, is it still working ok? was it the SwUpdated?
· Registered
In case somebody follows in my footsteps in the future, I figured out the problem. This thread on upgrading 2012/2013 wiring suggests using an HDMI/USB cable from an Acura. This will not work for Carplay (but nearly everything else apparently). You will need part # 39114-TR3-A21, which is the actual part for '14-'15 Civics (if you can find it).
Swapped this part out, everything works! Carplay in a 2012 Civic!
· Registered
This YOUTUBE video…
will give you accurate and simple to follow instructions to install APPLE CAR PLAY on a HONDA CRV EX/EXL 2015-2016 WITHOUT NAVIGATION.
The only alterations to the vehicle that is required is that you have to do is disconnect the COMPASS wire (instructions in the video). If you don’t, it will interfere unpredictability with the GPS signal from your iPhone and send you off in a random direction.
If I can do this, anyone can!
· Registered
Hey Everyone,
Recently, someone over at CR-V Owners Club posted a firmware update containing the Carplay beta, and numerous 2015-16 CR-V owners have flashed it successfully. I'm wondering if it is possible to flash this to our headunits. While they are not the same vehicle, I am hoping Honda did not go out on a limb and change the firmware/OS for a specific vehicle of the same model year (I'm referring to 2014-2015 civics with the new displayaudio headunit), and was wondering if anyone here has the balls to try and flash it. I do not have the balls, hence why I am asking if a bigger man or woman can step up and try it. I've added the links for both the thread and actual firmware update in this post.
Carplay Beta Firmware
crvownersclub thread
NOTE From reading crvownersclub, this may only work for non-nav headunits (I have one with nav)
If someone is willing to try and flash it, make sure you follow the instructions found on the crvownersclub thread, and report back your findings if possible. I would suggest only owners of 2014-2015 civics with EX, EX-L and SI trims try it.
After looking at the update file in a hex editor, looks like it is Windows CE. I wish I had a map update file to compare to, but I don't unfortunately.
DISCLAIMER: I am not responsible for any damage/issues caused by attempting this! Proceed at your own risk!
P.S. I've attached the dump of signatures to this post.I've removed all the zlib's as they were just taking up space.
Thanks,
achonda
the update works on the 2015 Honda CRV SE model and with easier steps.
the file is the same, however, the USB needs to be renamed as USB20FD in all caps, either format of exfat or fat32.
with your car in accessory mode and bluetooth turned off on your phone insert the USB stick in port 2 of the centre console.
the request of do you want to update the firmware from... to... proceed with yes, and wait, it may reboot again and install up to 99% and wait a few minutes. when it finally reboots the it will let you know when to remove the USB.
to bypass the audio code screen, start your car while holding down the start button for 10 seconds, then hold down the power button for 3 seconds and the follow the onscreen prompts again pressing power for 3 seconds.
there is a grey compass cable to disconnect from the back of the radio unit. it does not affect the cars compass display. failure to disconnect this cable may result in the apple car play maps to malfunction after a few weeks.
there is a link to a video that makes this very easy.
no need to use hex codes or modify the file in anyway, just name the USB accordingly. hope this helps, it is 2 years after.
I am extremely happy to see this work, the maps, and the music apps all show up, driving is safer too.
Plant Communication Device Gadget Output device Gps navigation device
Communication Device Vehicle Plant Personal luxury car Gadget
Vehicle Font Gadget Audio equipment Gas
Gadget Vehicle Gas Display device Technology
· Registered
Hey T.HendriXon what dash kit is that? I’m interested in retrofitting a CR-V head unit into my 2015 EX (non-nav) and I’d like to keep a clean OEM look such as yours. Thanks in advance!
· Registered
This is just the OEM Honda bezel for the 2012 models with navigation. It seems that the CR-V unit has essentially the same dimensions as the 2012/2013 navigation units, which means those OEM bezels would be a perfect fit. So, for your case, you could probably buy the 2013 bezel (part number 77250-TR6-C11ZA, I believe) and then the little black spacer piece that sits between the unit and the rest of the bezel. I wasn't able to find a part number for that one for some reason, but you can see it in this photo:
Plant Car Vehicle Automotive navigation system Automotive design
Definitely a little pricy, maybe you could find this bezel at a decent price used somewhere. Hope this helps!
· Registered
Thank you for the write up, but yeah I realized that soon after writing that, if you look at my post history I was able to locate the 2013 bezel and did the retrofitting, can confirm the fitment is perfect! Thanks again for taking the time to write back!
41 - 58 of 58 Posts
