1 - 4 of 4 Posts
I was installing GPS on OBDII port on my Honda Civic 2015 and I think I make a contact the 12 volt line on the OBDII with ground so now not power on the OBDII port , not radio, the main screen doesn’t work and the door with don’t lock or open with the controls any ideas thanks
Make sure you check the relay fuse block/ panel under the hood as well. Might need to use volt/ohm meter. The OBD port is a direct battery connection.
1 - 4 of 4 Posts
