1 - 5 of 5 Posts
Hi guys,
As i see, so many Civic owners replace the transmission filter which is installed outside of the AT and its under air filter box.
But, as far as i know, there is a larger filter (Strainer) which is installed inside the transmission.
I dont know the part number, but i saw this strainer listed on a diagram at Honda dealership, its price around 88 CAD.
Parts advisor said that he does not remember whey anybody ordered and replace that filter, which is looks strange for me.
It looks like this one (aftermarket): ATP® - Automatic Transmission Filter
Does anybody replaced this strainer (filter), by chance?
Interesting, I did not know, until now, that Honda had included an external ATF filter on our cars. Honda does provide a filter kit with remanufactured transmissions.
But that's what being retired for 8 years will do for current information.
All that said; it can't hurt to replace it, but I found no reference to a routine replacement interval.
25430-PLR-003 $42.08 is MSRP for the filter.
My guess is a dealer will charge at least .5 hour (maybe more) to replace the filter.
Hi Teeps,
As far as I know, there is an external filter (located under air filter box) - exactly that one you mentioned about.
But, Parts advisor at Honda dealership showed me a Strainer (Filter) which is installed inside the transmission, costs around 80-90 CAD.
He said that its never being replaced by Honda dealer, there is no reason to do that, based on his experience.
I changed the transmission fluid (drain-fill) today and I have found why internal filter is never replaced by dealers\Civic owners.
In fact, Civic 2013 transmission has no bolter pad which can be removed and filter can be replaced.
As I understand now, if you want to replace that internal filter, you need to remove the entire transmission and dissassemble it, as its like a walnut.
This job is expensive for sure, that is why nobody wants to do and pay for this.
Honda says that transmission filter's lifetime period is equal to transmission lifetime. In other words, you dont need to replace it :)
Actually I found a few photos of that filter (whats inside) after 80-100k km - its full of crap and needs to be replaced for sure.
So I made transmission fluid change first time for my Civic, I am going to make 2 more fluid changes after some time.
I will replace the external filter with 3rd fluid change.
I did not drill down far enough in the section to find what you were talking about.
But, there is was (A) in the illustration below.
And you are correct it would involve many hours to get to the strainer.
So yeah, no one is going to replace that internal strainer as part of preventative maintenance.
Unless there are major shifting problems with your car's transmission; I would not worry about either filter.
I agree, Teeps.
1 - 5 of 5 Posts
