Hello,
I'm experiencing a similar symptom to many that I've read about. When shifting to 2nd/4th/R, I can't engage the gear, especially in higher RPMs. If I push the shifter forward with a bit of pressure (i.e. jam into third) I can typically shift cleanly, with positive engagement, into 2nd/4th/R if I shift lightly. Pull the shifter back a little bit tougher (i.e. trying to shift quickly to merge onto the highway), and it seems to slip back into the "grinding" position. It's as if the shifter is sliding backwards at some point reducing the travel distances with the three "bottom" gears. Where would one look to see what is causing the slippage? are there links/connectors/adjusters along the shift cable that may be loose? Any common spots for this issue?
2012 Honda Civic EX Coupe 1.8L 5-speed.
Thanks in advance to anyone with any ideas!
