1 - 4 of 4 Posts
hey can you run 5mm wheel spacers on 2014 civic si without extended wheel studs . just looking for the max wheel spacers without changing wheel studs . not wanting to run 20mm or 15mm
I would not. 3mm maybe but you are not going to have full thread engagement.
If this is for aesthetics, 5mm really isn't even noticeable and not worth the risk IMO.
I'm not familiar with Si wheels. Would 5mm spacers pull the wheel hub and brake hub apart, putting all the weight of the car on the studs, because it does on the steel wheels.
1 - 4 of 4 Posts
