1 - 20 of 58 Posts
Supporting Vendor
Honda Civic License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Honda Civic. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Civic!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your Civic looks at night.
Brightness:
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of OEM! (92 lumens)
Bulb Design
SMD2: Similarly compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Civic).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Honda Civic Sedan License Plate LEDs
Honda Civic Coupe License Plate LEDs
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Customer Reviews
"These lights are amazing ! Super bright and great quality...shipped out fast and they came in the mail in like 3 days ! Will be buying more from this company !" (Posted on August 20, 2013) -Mark
"I just received my LEDs in the mail and installed them, they look great, way better than stock and I have been getting a lot of compliments on them. Definitely a great upgrade for my car, great job guys!" (Posted on March 12, 2013) -Aaron
"These led's light up the license plate area really nicely. They are so bright that they cast an underglow on the road. Nice luxury look for my car.
Thanks DD!"Posted on August 6, 2012) -BG
i went to your sight, and no interior kit for the 2014 civic. and, i went to get the license plate lights, all said 'out of stock'. what would an interior kit, trunk and license plate (2) run, once you had them in stock?
Supporting Vendor
Discussion Starter · #10 ·
It's hard to get a picture that shows just how great these look. I picked up the brightest set and they look fantastic. I was afraid that they'd be a bit much/ostentatious, but they are perfect. I couldn't be happier!
That looks awesome Ivan!
It's the OEM+ look
Thanks for posting
Nick C.
Supporting Vendor
Discussion Starter · #16 ·
Two questions:
-Are there any regulations against having colors for illuminating the plate? (I live in British Columbia if that matters)
-Any plans for purple?
Thanks ♥
1. We recommend sticking with white for the license plate location
2. It's unlikely we will offer a single-color Purple LED replacement anytime soon
We do have RGB products available on our site if you are looking to add some color to your interior
Thanks!
Nick C.
1 - 20 of 58 Posts
