1 - 20 of 117 Posts
Supporting Vendor
Honda Civic Fog Light LED Bulbs
Diode Dynamics carries LED bulbs for replacement of your Honda Civic's fog lights or DRLs, in all major sizes. They are available in HP, XP, and SLF models. This will make your Civic's fog lights a nice bright white (or yellow) that closely matches factory-equipped HID lighting! Just simple plug and play, replace the bulb and you are good to go!
Diode Dynamics offers the brightest, highest-quality bulbs on the market. Your order will ship same day, and we're here if you need us for support and service. These LED bulbs are designed by our engineering team here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several bulb models options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
Brightness
  • HP48: (265 lumens) Slightly Lower than factory brightness.
  • XP80: (510 lumens) Considerably brighter than stage 2 (not available for all vehicles). Great match with factory HID's
  • SLF: (Street Legal Output) Much brighter than factory. These are bright! USA Made
Bulb Design:
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Fitment. HP, and XP bulbs use an inject-molded terminal, with a full-size base connector, designed for exact replacement of your factory bulb.
Included in your order is TWO BULBS (to fit your Honda Civic).
Diode Dynamics' products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
Diode Dynamics: Fog Light LEDs for 1996-2016 Honda Civic Coupe
Diode Dynamics: Fog Light LEDs for 2006-2015 Honda Civic Sedan
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Supporting Vendor
Discussion Starter · #7 ·
Let me know when the XML2 is out in yellow please! I was so impressed with the first LED's I had purchased from you guys that I just put in another order.
I will be sure to post an update when they become available! We are working hard to make sure the color temperature is accurate and the output stays where we want it
Thanks!
Nick C.
Supporting Vendor
Discussion Starter · #9 ·
So if I purchase your XML2 in yellow (when they come out), I should purchase these to help put all that light to the road? Will it be a HUGE difference in output compared to the factory? I see the LED's are built in, will you even offer these with the XML2's?
Supporting Vendor
Discussion Starter · #11 ·
The XML2 is a plug and play bulb replacement for the factory housings. The Luxeon LED Fog Lamps are a complete LED housing replacement.
Nick C.
Supporting Vendor
Discussion Starter · #15 ·
LUXEON LED Fog Lamps (Type A)
SKU: luxeonA
Be the first to review this product
You could receive 20 Diode Points for writing a review for this product.
Availability: In stock
Ships today if ordered in the next 364 days, 22 hours and 48 minutes!
I have a year to order and it can be shipped today!
We are launching a new site in January
Nick C.
Supporting Vendor
Discussion Starter · #17 ·
This.......or........HID kit for fogs? HID will be better I'm assuming?
This is actually a better option than an HID conversion kit for the fog lights due to the perfect output pattern and the sharp cutoff. HID's may produce more light output, but the optics in the Luxeon fog light assemblies make them more ideal. Here's a quick example of the output on our FR-S:
Nick C.
Nick C.
I will be ordering within a month or so. Thanks Nick.
1 - 20 of 117 Posts
