1 - 20 of 384 Posts
· Registered
Over on the 8th Gen Civic board they have a long running sticky thread of pix of 8th gen civics and Honda/Acura OEM wheels.
We recently purchased a 2013 Civic LX in Dyno Pearl Blue.
I knew going into the deal I'd replace the wheels and tires...
Despise the Firestone Affinity tires and I would replace them with any number of OEM wheels I like much better.
I've got 97 Prelude 'blades' on my 2004 Accord LX
If you have a 2013 LX,EX,Si that you swapped stock rims for another variety Honda or Acura rim style, please post up the pictures
:dancingcoolsmiley::Banane08::wigglesmiley:
· Registered
Is there anyone who replaced just 16" rims?
· Registered
· Registered
They're also one inch wider than your Si wheels but should work okay because the offset is +45mm.
You can find quite a few of these for sale on ebay with the Michelin Primacy MXM4 235/45R18 tires that would also work but your speedo would register a few mph slower because of the larger diameter.
Spec: 18x8 size +45mm offset 64.1mm hub 5x114.3mm bolt pattern
1 - 20 of 384 Posts
