1 - 4 of 4 Posts
2013 Civic Si Sedan
So my cars battery can’t keep a charge and it dies to 0% before I have to charge it again. Everyone told me to replace the alternator because the voltage regulator failed and I did that and then a couple days later my new alternator is testing as voltage regulator failed. I put in another brand new battery and then tested alternator and it still said voltage regulator failed. So it’s not the battery and I highly doubt that both my old and brand new alternator have bad voltage regulators so something is causing it. Any thoughts? This code 61-11 along with some other airbag codes(I reset and they haven’t came on because the airbags were replaced) and tpms codes were on.
Communication Device Telephony Gadget Audio equipment Portable communications device
what brand alternator? denso is the recommended.
aside from you firing parts at the issue, its likely your battery sensor is the issue.
1 - 4 of 4 Posts
