1 - 4 of 4 Posts
I have 5300 miles on a 2013 civic. While coasting to a stop in dry conditions with my foot on the brake i felt and heard what I believe was the ABS engage once. What i mean by this is there was one vibration not the rapid repeating sound and vibration I have experienced when the ABS is engaged in slippery conditions. The ABS system has never engaged since I have had this car. The single vibration then happened several more times under the same conditions after which the ABS VSA and Power steering warning lights came on. The warning lights have gone off and back on 3 times since. The car currently sits at the dealer awaiting diagnosis. Any thoughts? I'm pretty disappointed to have problems with such a new Honda, not what I have come to expect in 24 years of Honda ownership!
I Drive Too Much
It could be a low voltage issue caused by a bad battery which has happened to others. These cars are very sensitive to having the proper voltage range or all kinda warning lights come on as well as odd symptoms.
Could be a wheel speed sensor too. It could be making the car think one or more of the wheels are on the verge of locking (which would, in turn, engage ABS), and because VSA utilizes the ABS system it would cause warnings for all ABS related safety systems.
1 - 4 of 4 Posts
