Ya it could be that the engine is bogging due to the percentage of power being sapped from the AC which causes a rough idleAll three of our Civics (2012 LX, 2013 EX, 2014 LX) do that. We've had 115°F heat, multiple weeks over 100°F.
Our 2011 LX Accord (2.4L I4) does the same, but to a lesser extent.
Our three V6-powered Honda-Acuras ... hardly notice it (bigger driveline?).
OF
It’s not the sound level. There is a vibrationThis isn't a "problem" so to speak its just the nature of the AC system. What you're hearing is the compressor cycling on and off. The hotter it is outside the more the compressor has to work to keep the AC pushing cold air.
Think about the noise that a normal air compressor makes (for air tools, for example), they are pretty loud but only when they are actively compressing air to fill the tank. The AC compressor in your car is smaller than a compressor in a full size air compressor AND it is compressing a refrigerant gas which is more dense than air, which makes it it harder to compress / less compressible, and in turn requires more work.
Its most likely functioning how its supposed to, BUT if it is exceptionally loud (and its already noticeably loud when its working just fine, mind you) it might need some lube on the clutch/pulley, or maybe it is over/underfilled with coolant. Like mentioned above check the AC system pressure and see what you get if its really howling, but if the air is still coming out at a consistently cold temp then its probably fine.
I have pretty stiff motor mounts and mine is extremely noticeable at a stop (very loud and you can FEEL the increased vibrations when it kicks in), but the compressor is fine, system @ correct pressure, etc.
How much did you pay for the service? Honda dealer I assume?We just had the AC on the 2013 EX serviced last year. Even at factory loaded refrigerant mass, it still vibrates, though now the vibration amplitude is noticeably less than the our other two Civics.
All three are running at near-identical pressures, but the 2013 definitely shoots colder air out of the vents at all temperatures.
Given the 2012 LX is ten years old, it's due for an HVAC service. I'll have my local tech recover the R134a (he can keep it), replace the Schrader valves myself, evacuate and charge to mass myself.
That should get it back to "factory cold" out of the vents and reduce vibration like on the 2013.
OF
Again, normal. When my AC cycles on, the engine idle does an on-and-off rough and smooth, similar to what you had previously mentioned.It’s not the sound level. There is a vibration
Just very curious what exactly is causing this. Certainly not all small engine cars are like this (I imagine)Again, normal. When my AC cycles on, the engine idle does an on-and-off rough and smooth, similar to what you had previously mentioned.
I think it was just $80, but this was before refrigerant prices went way, way up this year (as in more than doubled). I'd guess it would now cost me easily over $100 with current prices.How much did you pay for the service? Honda dealer I assume?
