Hi folks! I need some help. Here is what is going on with my air conditioning...
My wife recently spilled a bottle of juice on the dash of our 2012 Civic LX. After cleaning up what liquid I could without pulling the dash apart, the Climate Control Panel died. None of the lights would illuminate and the fan would not turn on. However the temperature control and AC compressor button still seemed to work. But with no fan, it was useless. All the fuses were fine. I removed the panel, cleaned the circuit board with contact cleaner, but no luck. Its a fairly complex looking board with multiple chips on it so I concluded that the electronics must be fried.
I ordered a new HAC panel from eBay. (Honda discontinued the part for the 2012 so the only thing I could find was a used one) I matched the part numbers and received a replacement from supercarparts for $35. Im guessing a lot cheaper than it would have cost if I could have found a new one out there! After plugging in the new panel, everything immediately began working fine
, BUT, I don't seem to have control of the Recirculate function. When I turn the car on, the orange recirculate button will light up and it appears to be in that mode, but if I toggle it off, it will NOT come back on. The button now is inoperative...until I turn the switch off and restart the car. So it works initially but, you can't go back in forth between fresh air mode and recirc mode.
Is it possible that this is a software issue that Honda could fix? Or does it sound like a problem with the new HAC panel? I am considering ordering another panel and seeing what happens, but I'm not so sure there is anything wrong with it.
Any ideas, wisdom, or advice?? My thanks to anyone who does!
