1 - 13 of 13 Posts
Picked up some wheels, 18x9.5 +27 Enkei's (used stock 18" tires - 225/40/18)
Switched to e85
In process of switching from KTuner to Hondata
Land vehicle Vehicle Car Automotive design Mid-size car
Reactions: RRCoupe
Discussion Starter · #4 ·
Discussion Starter · #6 ·
Any rubbing with the new set up? I think u r on H&r/truhart struts right?
You're correct with my suspension setup + rear camber arms. I was rubbing in the back until i had the fenders rolled, now only larger bumps or fat people in the car causes rubbing.
Are you running any negative camber? Rears look pretty straight up and down.
Discussion Starter · #8 ·
No negative camber, i'd like these tires to last a little while. Prefer to have as much contact patch with the tire as possible.
Although, with the tire stretch i'm scared to take corners as hard, no because of the rub, but because of the tire coming off the bead.
Yea 9.5 wide with a 225 is a little hairy. Cost of looking good imo.
Discussion Starter · #10 ·
My buddy has 9” wide wheels with 205 tires. That’s too extreme for me.
I was going for the aggressive stance without the crappy camber
Eh i was running 215/45 on 17x8.5. Negative 2.5 in the rear about a degree in the front. No wear issues, but I stay on my rotations and flip the tires periodically. I have directional so that makes it a little easier to prolong the life. I'm on the same suspension you are.
1 - 13 of 13 Posts
