I have recently installed an Audio Control LCQ-1 (line output convertor plus eq) in my 2013 EX sedan with non premium sound system. When it works properly it is great!
Heres the setup:
-speaker level output from stock stereo to Lcq1
-RCA out from LCQ1 to both sub amp(300 w bridged powering a pair of kicker solobaric subs) and 2ch amp (50w x2) for -Front kicker components
-Remote turn on output from LCQ 1 to both amps
LCQ 1 gets both 12v switched and 12v constant from stock radio harness and is grounded to chassis.
Neither amp is especially power hungry(this is not an SPL machine, I just want clear loud music). Each is supplied with 8 ga power and solid ground to chassis.
The problem:
when I turn on the key, I get an EXTREMELY loud garbled noise output from all of the speakers that can only be stopped by pulling the power from the lcq1. After a few seconds I plug the power back on and all is back to normal. Sometimes when I get in the car and turn on the system it turns on just fine. I am on my second LCQ1 from crutchfield so now I am wondering if there is something about my setup, or the car itself that the LCQ 1 just does not like. I have actually ordered a Kicker Front row to see if it will work for me. (I should have it later this week) If I can get the LCQ1 to work reliably, it will be the ideal solution with its LOC capability and great EQ features.
I have considered grabbing power for the LCQ1 directly from the fuse block, but it only draws 350mA so I don't think there is an overload issue with my current setup. I figured that if there was I would have blown a fuse.
Also, I have noticed that the LCQ1 powers on at times when I have not even turned the key such as when I unlock the doors with the remote and when I put the key in the ignition before even turning it on. I have the turn on lead of the LCQ1 connected to the acc lead on the stock stereo harness. So why doesn't the radio power on like the LCQ 1 powers on under these same conditions?
Sorry for the novel. I guess I would just like to see if anyone else has had similar issues with the LCQ1 and if you have had success with it in perhaps a slightly different setup.
Thanks!
Heres the setup:
The problem:
Thanks!
