1 - 18 of 18 Posts
My 13' Si coupe started acting weird in the shifts. Goes into gear, but if I drive it hard, the position of the shifter changes. The video might not make it obvious, but when I force the shifter down in 2-4-6, the shifters neutral position lowers as well.
Yeah that is stretched. I had the same issue almost about a year ago. Just order new cables and swap them out. Mine was worse tho, my car wouldn't even go into reverse because I broke the cable right where it links to the gear selector on top of the trans.
maybe upgrade to the hybrid racing shifter cables.
I was looking at those, but they aren't in stock until August 14th, and this is my daily.
I've only done regular maintenance. Is the install something I should hit up a shop for?
i think i saw a video somewhere on YT. I heard it's not hard, just tedious. If you're mechanically incline, then I would say it's something you can do yourself. But, I haven't personally done this upgrade. I was looking into it.
How do these cables stretch? Is it because of a short shifter or what?
Sent from my iPhone X while on the toilet.
Maybe the old owner was heavy handed with it? I'm 10k into it, keeping it all stock.
Even idk how that’s possible. I’ve never had cables stretched on any of my cars unless I had a short shifter.
Installing new cables is easy if you have jack stands to put the car up on. Installed a new set of oem myself, ive got a short shifter. Got oem For $140 and needed my car asap so wen with them for now and will upgrade to the hybrid ones
2015 Honda Civic Si Coupe
Yeah I don't understand how it happens. I really didn't know it was thing until I joined a FB group.
Discussion Starter #12
Man, I shoulda just done what you said. I'm a newbie, so I really only do maintanence stuff and don't touch anything that isn't obvious. Yesterday, I called my car guy friend and asked if I could buy the parts and do it myself. He doesn't know my car, but said something about I shouldn't because of some sort of alignment I might need to do? Idk any shops, so I went against my gut and took it to the dealer like an idiot...
I described the issue to these dudes. I definitely said it doesn't feel right and I think its the cables in the linkage. They charged me half an hour for diagnostics, only to tell me they couldnt replicate the issue, but said theres definitely more play than there should be. Sent me on my way saying I should monitor it and consider tranny fluid drain and fill...
I'm so mad at myself, lol... I think I'm just going to attempt to swap everything myself...
is your car stock or do you have an intake?
Just do the swap yourself. Mine broke last fall and was able to get it done in less than 2 hours. Just make sure you get the plastic in the center of the car out so you have plenty of room to get under the shifter. You also just need a lift or jack stands to get under the car where you'll need to remove the heat shield and like 2 brackets where the cables bolt on. It's not difficult or scary. I think I found a diy for an 8th gen and it ended up helping me a ton.
Discussion Starter #16
Yeah, I looked at the hybrid racing guide. This should more or less be the same, right?
There you go good find. Was going to say if youre stock you have to move the intake box out of the way. I do suggest doing the acuity shifter cable bushings at the same time while youre there
1 - 18 of 18 Posts
