1 - 4 of 4 Posts
I was thinking about getting a short ram. What I have heard is that relocating your batter is good so you could put the short ram where the battery was. Is that correct if so how would I do that. I have a 2012 civic si
Most cold air intake kits will have a battery relocation kit. Skunk 2, acuity, some others. The short ram stuff for these cars will just go in the factory box location. There are diys about relocations on the internet, but its usually to the trunk. Google is your friend.
Baned
Also be aware that the relocation kit has caused some members to have issues with shifting because it gets in the way of either the even gears or the odd gears. I can't remember which. If you install the kit and make sure that it doesn't touch anything you should be okay.
1 - 4 of 4 Posts
