1 - 4 of 4 Posts
Hello all,
I have a 2013 4door and am looking for the best bang for your buck complete suspension set up? I was looking at the hfp set up but it seems that it would only work on the 2 doors.
Thanks for any suggestions.
Hello all,
This really depends on your goals. Are you just looking to lower the car? Is this a daily driver? Will you track the car?
For a mild drop, some springs will do the trick. If you want adjustability, I would look at the tein street basis z. Very affordable
Fortune auto also have very well made stuff for a bit of a higher end setup.
Welcome to 9th gen.
If you haven't already done so, check out the Suspension section. Much info there.
HFP is probably best bang for your buck and rides better than stock.
Fortune Auto if you want a comfortable ride and be able to adjust ride height.
Just changed my HFP suspension for Fortune Auto after 2k because I wanted to go a tad lower.
Sent from my Pixel 2 using Tapatalk
1 - 4 of 4 Posts
