1 - 18 of 18 Posts
Hey guys, I did an rbc swap not too long ago and im getting tuned, the tuner is basically done and when im trying to do pulls for the last datalog its stopping at 6500 rpm. He said its something mechanical does anyone know what could be the issue?
Thank you
Motor mods:
RBC (8th gen)
1000cc injectors by southbay
stock air box
skunk2 downpipe
ktuned catback
We would need more info. When you say it bogs, what does that mean. The rpm stops increasing?
Is the car going lean?
Did the tuner check to make sure there are no protections in place by accident? Rev limiter too low, lean protection in place etc...
Who is tuning the car? Can you post a datalog.
Discussion Starter · #4 ·
Yes the rpm stops increasing. Im being tuned by Kyle Handy he double checked things and said its most likely mechanical issue. How do I upload a datalog onto here it says not allowed.
agreed on more info...
how can 1000cc injectors with a stock pump work.
is this a recommended configuration?
Discussion Starter · #9 ·
Could a broken battery terminal cause injectors to shut off? Car still runs and everything just has a crack in it so it doesn’t really tighten super tight
Should be able to add it as an attachment to your post, unless they changed something. It would be really helpful to see.
Kyle saying it's "mechanical" gives us nothing to go on.
You should fix it to rule it out. Battery/ground issues can cause all kinds of problems.
Also, you may not be able to post attachments until you have been a member for a while.
Discussion Starter · #12 ·
Fixed the terminal and it’s still doing it.
My injector clips aren’t soldered does that matter?
It shouldn't but again it's another thing to rule out. How are they connected now? Tape, butt connectors?
Some small black heat shrink tubing and some electrical tape.
I personally would never run it like that but I also can't say it's causing the problem. Why not solder the connections, heat shrink and be done.
Discussion Starter · #17 ·
So I figured out that if I rip it in 1st with traction control off and don’t grip and just spin it will go to red line and then if I shift to second redline then third it goes up to 7000 rpm?
1 - 18 of 18 Posts
