1 - 9 of 9 Posts
Hello everyone, I believe I have a simple bolt on sheet I’d like y’all to take a look at and give some opinions on the items and see what can be changed or taken off. The build is for something that can be basic N/A for now but later on have the possibility for going F/I later down line. Any help with the build sheet would be appreciated TIA.
P.S I have the Ktuned exhaust, buddy club short shifter, and Hasport upper and rear engine mounts already
Engine/Bolt Ons
Hondata 500$ (bought off someone)
Acuity CAI (RBC) w/battery relocate - 420$
RBC Manifold P&P Kit -?
Ktuned Catless DP - 399$
Sirimoto E85 Flex fuel w/injectors -849$
Transmission
Clutch Kit -?
Sirimoto CMC Kit - 200$
SS Shifter cable -?
Kseries Transmission Springs - 26$
Acuity Shifter BB - 29$✔
Acuity Shifter CB - 70$
are you planning on going turbo or supercharger? If supercharger, I wouldn't mess with getting the RBC manifold (unless the KW kit can utilize the RBC). As for clutch, just depends how much hp/tq you are shooting for. I'm at 366whp/296wtq and have a CM FX300 and it's been holding up just fine.
FYI - Kraftwerks kit comes with a RBC style manifold. No need to purchase separately.
Discussion Starter #5 (Edited)
I plan on going turbo later down the line and I know PRL has a turbo kit that has the RBC manifold as part of it. But I kind of just skimmed through it as I don’t have any plans on going that route just yet. As for the amount I’m shooting for with the basic bolt ons I know it won’t be much but probably around 250 if possible and with the boost I’d like to reach around 500ish, but I know at that range I’d have to build the transmission due to the gearing being weak at 400ish HP ranges.
I’ve skimmed into the KW kits and the PRL turbo kits and I like them both but in my personal preference I wanna go the turbo route.
got a pretty good list there. the acuity intake is a pretty piece i love mine.
Thanks I tired to look into the simple bolt ons that everyone has posted about in the forums, and came to a little list of bolt ons with possibility of going F/I later on. As for the acuity intake yes I’ve seen nothing but good reviews about it being the best bang for your buck intake on the car.
1 - 9 of 9 Posts
