1 - 7 of 7 Posts
Okay so my car has a natural camber and it has a lot of camber wear.
I'm not trying to have camber. So question here is do you think I should flip my tires any time soon and how can I get rid of the camber. I know a camber kit is an option, but what else can I do. Are there any camber kits out for the 2013 lx yet? I'm really not trying to have my tires eaten up this quick. IMG_20140323_175711.jpg IMG_20140323_180007.jpg
Discussion Starter #2
P.s I only lowered it about 1.7 inch drop in the front and about an inch drop in the back. Do you think an alignment would help fix this problem or do I need a camber kit?
Did you get an alignment first of all? If not you need one asap
Sent from AutoGuide.com App
and after that you will get your answer if the camber kit is needed or not
Blues Clues
camber arms are roughly 150, most 8thgen camber kits will fit just fine
your tires will probably already have a wear pattern ground into them that they may not balance when you change alignment settings or camber/alignment now.
1 - 7 of 7 Posts
