1 - 5 of 5 Posts
Hey guys I have a 2012 Si that’s got the oil burning issue. Can I add 5 quarts of oil when I do the oil change? I change my oil every 5k but I don’t want to risk running it low. Would adding 5 quarts be harmful to the car?
I would not overfill the oil, not that much anyways. Check it regularly and top off when needed.
You can do damage with too much oil, as well as too little oil. I second filling to correct height and checking at each fuel fill-up.
With today's uber-reliable cars, it's a good habit most of us don't do anymore.
Baned
How much oil does the Owner's Manual say to add? Are you changing the oil filter when you change your oil? If you are, that requires a slightly different amount of oil than if you aren't. I also recall reading in the Owner's Manual years ago for my 2012 Si that Honda recommends checking the oil level every time you get gas. It's a pain, but what else are you going to do for the 2 minutes it takes to fill your tank? Might as well be something useful like checking your oil!
2015 R18Z1 Civic Special Edition
Burning eh? I would try the liquimoly motor oil saver. It's part no. 2020, can be used every 15-20k.
Sounds like the rings are dirty in which a PEA based fuel system clean along with a detergent not solvent based crankcase cleaner might help. This all can be done at once with the Gumout Multi System.
1 - 5 of 5 Posts
