1 - 8 of 8 Posts
I have a 2012 Honda ex 1.8l with the message check charge system. I have checked battery and alternator and all the fuses in engine bay. They all check out fine. Why is light still on?
How did you "check" these items?
How old is your battery? Have you checked your serpentine belt tension?
I have a new tensioner just put on week ago. And battery checks out. Had it load tested. Its a agm yellow top.
Have your ELD checked out. Sometimes when this component goes bad, your battery light can come on when the rest of your charging system is fine.
Discussion Starter #8
If the ELD fails,you will get a CEL on in addition to a warning message.
The battery,alternator and associated connections need to be checked.
[/QUOTE
I will check the connections when i get off of work.
1 - 8 of 8 Posts
