1 - 13 of 13 Posts
New to this site and was curious about tuning when installing a new lightweight flywheel. Will be installing a new clutch and I'm debating on getting a lightweight flywheel but don't wanna drop the money on flashpro to get tuned. If anyone has a link to send me then that would be nice or give me some info
I've never had a problem with flywheels messing with the tune.
That's what I was checking. I'm not tuned now. If I install the flywheel I will have to tune it won't i?
How or why does this change the tune? I just want to understand what's going on.
Thanks
Thanks
The first time I read the OP, I thought he wanted to know if he had to re-tune his car when he swapped it over to a lightweight flywheel. In that case, No, you don't have to re-tune because the flywheel doesn't change how the engine breathes.
Once I read it again, I think he is asking if he has to have a tune in order to use a lightweight flywheel. In that case, Yes, you need to have a Flash Pro in order to use a flywheel that weighs less than 14 lbs.
I'm just trying to understand why. I'm guessing more timing (advance) or how and when it comes in due to the quicker revs.
I agree if your specifically talking about tuning (air fuel ratios and timing and such) then no you don't need to tune for a lightweight flywheel, the only thing you will need Flashpro for with a lightweight flywheel is to shut off misfire detection because you car I believe will go into limp mode(not totally sure on that) without shutting off misfire detection. So yes if you are getting a lightweight flywheel you will need Flashpro to make your car run with it properly otherwise don't bother putting one in and stick with an 8th gen stock flywheel
Honda went from a 12-tooth crank trigger to a 60-tooth crank trigger with the 9th gen. This allows the ECU to see higher resolution as far as when the power stroke begins. The ECU expects a ∆v/∆t (change in rpm over a given amount of time) for a given combustion event o fall within a certain range, and when there is a rapid change in velocity (like you get with a lightweight flywheel), it is perceived as a misfire event.
Thanks ER
Reactions: The Engine Room
I Drive Too Much
You better stick with a 9th Gen clutch and flywheel. No f/p means no other options at this time.
  • Hello, new here also, sweet forum! I purchased an exedy stage 1 organic disc w/ lightweight flywheel and I don't wanna put the light weight in because of emissions and many other reasons listed here earlier. I have flashpro and intend on tuning the car but inspection is coming up soon. I heard I could put the 2006-2011 8th Gen flywheel on my exedy stage 1 organic disc and everything will bolt up fine for the 9TH GEN. Not requiring disabling misfire detection. Do I have other options for flywheels with this kit? Do I go OEM From the dealer? Or napa, autozone, rock auto to save 250$ The supplier for the clutch kit isn't very fond of exchanges or refunds. Thank you
1 - 13 of 13 Posts
