Hi everyone!
Looking to delete the CDV. I understand that there are 2 12mm bolts holding it onto the tranny case, and one 10mm nut for the clutch line.
In attempting to loosen the 10mm line, the assembly it is plugged into turns with it as well.
This may sound dumb, but am I to hold that piece that is also turning as well in place, while simultaneously loosening the 10mm nut?
I have attempted to loosen the 10mm nut, but it is so stiff that the nut itself has actually bent.
Also, when I turned it a bit, the clutch line turned with it (not good).
How the hell am I supposed to get this loosened?
