Now I know many of you have dealt with this issue and/or maybe currently dealing with it… it’s that little ‘queif’ (dunno how you spell that 😝) sound from clutch every so often typically while coming off of a stop in 1st gear.
I remember investigating and reading about this when I first purchased the car a little over a year ago, I believe people said things like it’s a design flaw and the pressure plate is to small for the housing or some weird stuff like that, others said it was a release bearing, and then there were folks whom had replaced clutch/flywheel/throwout bearing/CMC & Slave etc and the sound STILL didn’t go away.
My question is, WHAT IS IT? And what do I need to look out for or service more often or anything along those lines??
The clutch feels fine, no slipping, grabs/engages smoothly (for 167k!). Only modifications are Acuity shifter cable bushings and knob. When I first got the car it would sometimes go days/weeks without making a chirp but it’s becoming more frequent as of late maybe like 1-2 times a day but it also seems to have gotten worse with the cold weather… I’ve found that applying minimal throttle and kind of rolling into 1st gear works best for avoiding the noise
