1 - 4 of 4 Posts
So recently I've had my head swapped and went supercharged. Car hesitates to start up, check engine light is on with code p0365 which is cam sensor lack of voltage, so I did put a new sensor in and the code still pops up, my check power steering and check vsa light is on as well
I assume this is a k24z7/si?
Who did the head swap and what head are you using? Are you sure there isn't a broken or pinched wire somewhere?
Is everything at tdc and timing chain tensioner properly?
Also, be sure the battery is strong. A weak battery is the most common cause of vsa/power steering lights.
Yes k24z7, and same head from another 9th gen, my friend did the swap, battery is brand new. Thats what I was thinking maybe something with the timing chain, the wires look fine from what I see
I would check the mechanical timing before moving forward.
1 - 4 of 4 Posts
