1 - 3 of 3 Posts
Hey
So I just installed rev9 coilover but When I raise my car up on my lift. The rear strut are tight and don't move. But when they are on my wheels on normal ground, and driving around. The rear strut seem to become loose and wiggle around top.I don't know if I messed with the preload or what. But need to know what's wrong
Thank you!
Check to see it there's any banging against the exhaust.
Also, was the rubber installed?
Possible the upper strut mount is not torqued properly? You need something to hold the center stud while you torque it.
1 - 3 of 3 Posts
