1 - 20 of 42 Posts
Coilover / Lowering Springs / Sway Bar / Camber Arm Installation
EDITTED: I've worked on an abundance of cars, so instead of posting it all on here, you can check out more cars I've worked on @ http://instagram.com/waisgarage
-just as good as a professional install. only difference is the price
-located @ 94538 zip coede region
-keep in mind that the initial height right after installation will become lower because the springs need time to settle
If you are still interested, send me a PM and I'll get back to you. Most likely you'll have to drive to me, or I can drive to you which will include gas price.My current set up is using a K-sport kontrol pro set.Here is my
car
members' car i worked on:
jiliu1234
coils: Megan Ez Street
preview:
kcoyocoils:
BC Racing Coils
preview:
Before:
AFTER:
VjJVvP6.jpg wRndWHa.jpg 7pkrAia.jpg 1267886_10202046660633220_1732458720_o.jpg
Jeffrey(owner of an 8th gen, not on this forum for obvious reasons :p)
coils: Buddy Club N+
preview:
coils:
Before:
AFTER:
A Friend's EVO X Gsr(Lowering springs installation)
Springs: H&R
BEFORE:
DURING:
AFTER:
Discussion Starter · #2 · (Edited)
MORE CARS:)
EVO X (Lowering Springs)
Springs used: H&R
DURING:
AFTER:
2002 LEXUS GS300 (Lowering Springs)
BEFORE:
DURING:
AFTER:
8TH GEN CIVIC (EiBach Sway bar + Lowering springs)
DURING:
AFTER (Hasn't settled):
forum member uaeone (Camber Arm Install)
Camber arm used: GodSpeed
Discussion Starter · #3 · (Edited)
eric yi's 2006 Acura RL
Lowering Springs:
Before:
During:
After(hasn't settled so pictures do not do justice):
Aaron's 2013 Subaru WRX(BC Racing's Coilovers)
NO BEFORE PICS
During:
AFTER:
First Generation Odyssey (Lowering Springs)
Springs used: Tein
No Before PICS
During:
After:
Toyota Prius(Lowering Springs)
Springs:
Before:
During:
AFTER:
13 Honda Civic Si Sedan (Coilovers)
Coilover used: Godspeed
During:
After:
2000 Honda Civic (Coilovers)
Coilover: D2 Coils
During:
After:
Discussion Starter · #6 ·
Discussion Starter · #8 ·
NIcce. I should have hit you up 5 days ago b4 I got mine installed!
Great to know you do this kind of work installed.
yeah man! hit me up next time if you know anyone else who needs it or if you need it. I don't do steep prices, they're cheap as f*ck.
Discussion Starter · #10 ·
I can get 8th gen springs as long as I get the rubber parts for the rear right? How much to install em?
I'll message you!
awesome, if you're still doing this next year when I get my coil overs I'll hit u up. I did my springs myself but I moved and no longer have the tools :(
Discussion Starter · #13 ·
How much do you charge and were you located
Hello! I'm located in the 94538 zip code region and price can be negotiable. Please contact me on fb @ https://www.facebook.com/Waikyaw or text me 5103784150 for the price. I do not like announcing it online. You can also private message me, but I might not reply as fast.
No problem dude! I will be doing it until my fingers can't move any more :p
Discussion Starter · #14 ·
Worked on my first eight Gen today!! check the main post.
sayswai hey man when you do work on 8th gens and lower them make sure you re tq the steering rack they pop and clunk a lot once lowered
Discussion Starter · #16 ·
Is this a common problem? The guy has not stated he has heard any noises from the front. Also the steering rack was not touched during installation unless you're bringing it up just for reference.
yes this is a common issue there is a tsb for it from honda but it normally is a lot more present when the car is lowered.... i know you dont touch the steering rack to do suspension install but its a good idea to go over those bolts so there isnt any popping or creaking
Discussion Starter · #18 ·
Thanks for the info, i'll keep that in the procedure.
Hey I know it specifically says "coilover/lowering springs installation" but I can't really afford that at the time (being a student and all) I was wondering if there are any other methods to lower my car. I drive a 1999 Toyota Corolla DX btw. I saw that people cut springs? What is that? And if you do that. How much do you charge per spring?
1 - 20 of 42 Posts
