You need a tune to account for the lean condition
I was told that it’s nothing actually wrong with it just flashing due to the mod being added . Plus I know I won’t get EVERY Single HP boost with the intake without tune but I also know I don’t actually 100% NEEED one to do it because it still makes a bit more powerYou need a tune to account for the lean condition
Now that you have a presumably larger air intake versus the stock one, your engine is now receiving more air into its combustion chambers, which is why you're getting a check engine light. Like Jn2k said, you need to have your car's ECU tuned in order to compensate fuel for the addition of air that your car is now receiving. Otherwise you're running the engine lean.& why would that happen? Gotta remember I’m new to mods and just asking questions about the situation
Consequences of running your engine lean is an overheating engine, damage to valves, piston heads, head gasket, spark plugs, etc. Your exhaust system, moreso the cat, could also suffer damage from the now hotter than optimal air exiting your engine.
It is your car at the end of the day, and if that's how you want to run your car, it's ok. But, I wouldn't risk the future problems you may have over a mod that gives you no perceivable difference in performance other than cool noises. I would say it's important to get a tune using a Ktuner or Hondata device before messing with any powertrain mods. That way when you add a mod like a larger air intake or a different exhaust system, you have the tool you can take to a tuner in order to compensate for your newly added items.
No, you need to get a simple tune or take off the intakeWould replacing my cars oxygen sensor work or tube is the only option
