21 - 40 of 74 Posts
2012 civic si
Discussion Starter · #21 ·
Not much has happened with the car the past few days.. mostly been focused on getting parts on order so i can keep wrenching. I think (fingers crossed) ive got 98% on its way.. im sure there will be a few loose ends
I pulled the rad and ac condensor out today. Condensor still had some pressure in it.. not much coolant left in the rad but it was a pleasant sight to see OEM fluid
White Automotive tire Motor vehicle Automotive design Gas
The rads fan shroud is pretty buggared (pictured above) glad i ordered a new one.. however i probably could have fixed the ac shroud, just the one broken tab on it (pic below)
Sleeve Hood Grey Helmet Glove
2012 civic si
Discussion Starter · #22 ·
I also built a passenger side headlight
As i mentioned in my video before getting this car i had picked up a set of 2012 coupe headlights. They were cheap and i honestly prefer the zenki style over the kouki. Bring back amber! 馃槴
The passenger one had a badly damaged rear housing but the lens and reflector where still in great shape
My kouki 13 headlight (passenger) had a good rear housing.. well a better one. The lower bracket was MIA and it had a small crack. But it was nothing that was beyond fixable
So here it is (left) all done. 12 lens on the 13 backing. My drivers side 12 headlight was in excellent shape and needed nothing. On the right is the old discarded parts
Motor vehicle Bumper Automotive exterior Gas Automotive tire
Heres the bracket i replaced. I cut it off the old backing and epoxied it flush to its proper location on the "new" backing.
Automotive tire Tread Wood Grey Bicycle tire
And this is the crack that was repaired. I drilled two small 1/16 holes at both ends of the crack, plastic welded it along its entire length and then added a top layer of epoxy to seal it up and ad a bit extra strength
Tire Automotive tire Hood Tread Wheel
2012 civic si
Discussion Starter · #24 ·
Nice progress. You鈥檙e better off getting HS parts instead of oe parts especially if they鈥檙e back ordered
I ended up ordering a progress 22mm RSB.
I also have rpf1s on the way.. no crash bolts yet, keep forgetting
Im considering putting the progress bar on my 8th gen si, and moving the 20mm bar from that car onto my fb6
2012 civic si
Discussion Starter · #26 ·
You鈥檙e going to want the 24mm progress instead.
I tend to usually air on the small side for sway bars, with my driving style i find big bars can be a bit erratic.
I ran my 10th gen with stock sway bars and found that i had no issues getting it to step out if i wanted to, it was highly competitive for me so i didnt ever find the need to up size
But I suppose its all up to opinion and driving style, to each his own
I found the 24 to be too small. I鈥檓 used to 32mm bars on my hs mini. I think the asr bar is also 32 splined on the sts CRX and that gets more loose than my mini did.
The bar made sweepers a lot better. I鈥檝e yet to spin on autox courses with this bar. On track it鈥檚 more than enough.
2012 civic si
Discussion Starter · #28 ·
Fair points, ive seen lots of rear sub frames tear off from big bars on EF/CRX's 馃ぃ
I definitely see the advantage for sweepers and slaloms. My local courses are so small we dont even really know what sweepers are... lol
2012 civic si
Discussion Starter · #31 ·
Nice. I think you鈥檒l like the 8th better but it would have a tougher time on tight courses
Absolutely. Will be nice to have the versatility of both
Hows helmet clearance for you? Im not a very tall person and the 9th gen is pretty intrusive.
The only way i can clear is to go full 2PAC spec, not the most ideal position for aggressive driving
Helmet clearance is shit on every Honda I鈥檝e driven. You need to adjust the seat to fit it. I have short legs so I sit really close but have the back out a bit so mine doesn鈥檛 hit the top
2012 civic si
Discussion Starter · #34 ·
In for a little update!
Interior has been fully detailed and its lookin good! I was also finally able to wash all the dirt off the outside.. i plan to do a paint correction down the line but for now ill just settle for it being clean
It has about 437 rock chips ill need to fill, thinking about trying the doctor color chip repair system.. anyone here tried it? Pretty pricey to ship up here to Canada. It also is severely covered in fallout.. ive ordered clay and iron x to deal with that!
I went to town the other day and picked up a bunch of parts, more still trickling in... yesterday i did an initial mock up of the front end and its looking pretty good however ive ordered a new passenger side headlight bracket as both of mine were bent!
2012 civic si
Discussion Starter · #35 ·
Ohh and of course some pics!
Possibly my favorite purchase.. 馃槏
Hand Hood Automotive lighting Car Automotive design
225/45R17 rt 660 on the left - 215/45r17 indy 500 on the right. Race/daily combo... new rad and ac condensor hiding off to the side there as well as some oem honda goodies for the front end!
Tire Wheel Automotive tire Tread Synthetic rubber
My brake package! Brand new rear calipers, coated blank rotors and dynamic friction track day pads
Shipping box Packing materials Package delivery Wood Gas
Some more oem goodness hiding out.. k&n drop in as well. And my new weathertech trunk liner!
Automotive parking light Automotive tail & brake light Car Vehicle Automotive lighting
Speaking of weathertechs 馃槏 floor mat porn for a canadian 馃ぃ
Car Vehicle Automotive design Motor vehicle Personal luxury car
And ill leave you with this! Oem hood and fender mock up
Wheel Tire Vehicle Car Land vehicle
For a easy to find option you can use Meguiar's ultimate wheel cleaner as an iron remover on paint. It has iron removing properties and actually works really well on the car.
I inquired at the dealership about cost of OEM shift knob and they quoted me something like $250 which is pretty insane.
I'm running the Firehawk Indy 500 on my wife's car. Dry grip is good, wet grip is okay a bit loud and ride is a bit harsh but drives nice on the highway. Good tire for the price.
First thing I did was get Weathertech floor mats they are invaluable keeping the car clean. I'm using 8thgen Civic sedan trunk liner fits perfectly on 9thgen.
2012 civic si
Discussion Starter · #37 ·
I ordered an adams package off of amazon, but good to know for future use!
250 is actually a wicked price for that knob! 馃槼 list at my dealer was 415, i got it for 351.. ouch
Good to know on the indys, im used to dailying 200tw tires and ive even been known to daily NT01s.. lol. So noise shouldn't really be an issue to me
Yeah weathertechs are worth their weight in gold. Both my girlfriend and my moms Si's are running them as well
2012 civic si
Discussion Starter · #38 ·
Removed the clutch delay valve today, is that HS legal? Nope. Do i care, nope lol
Its not something that will make me faster, but should give me more reliable 1-2 shifts and prolong that syncro's life
It was also the easiest time in the world to change, as the radiator is still out of the car
Tire Hood Automotive tire Automotive lighting Motor vehicle
21 - 40 of 74 Posts
