Aluminium Member
Derlin is good stuff.
Find out if it's acetal resin or ptfe filled acetal. Either way it's good with the added benefit of lower friction, I'm not sure what application they are using them for in this set-up.
Basically an engineering plastic. Not much give to it, so you probably won't notice a ton of difference between that and the aluminum bushings.
Also, I'm looking at other alternatives aside from the usual hybrid racing and ktune shifter cable/base bushings. So I was curious as to if anyone had experience with torque solution products in their shifter.
