1 - 20 of 21 Posts
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: 9gen
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid only for the lower 48 states.
I like the concept but I don't understand what this offers over an analog torque wrench. Maybe I'm just not thinking it through entirely.
There are a number of advantages. First, setting the Torque, and changing from Ft.lbs to Nm is much easier and quicker. Second, you get a warning light and are able to watch the torque applied in real time - so you have less of a chance of over-torquing. Third, the wrench will display the highest torque hit so you know exactly how much torque was applied. And last, you don't have to remember to turn the wrench down to its lowest setting. Forgetting to do this can cause the wrench to go out of calibration.
BLMW
we have digital torque wrenches at work for the quality guys to go around and check torques on all parts of the engines and they look just like that almost
You Don't know Me!
Bump, I remember you were also a vendor on ephatch.com when I still had my EP3.
i picked up one of these a few months back and have not regretted it one bit
definitely a great bang for the buck
Community Director
Nice to see a small review. I was wondering if anybody bought it yet and how is it compare to other torque wrench?
the only other wrench i have used was a beam style.. so it blows that out of the water. i got mine during a sale for 100 shipped, which is comparable to the price of the craftsman clicker style, but from what ive read, those clicker wrenches arent so reliable.
only thing that is a pain is if you bump it on something, itll turn itself off. and it only stays on for 4 minutes. after that, it shuts itself off when not in use, so you have to turn it back on and set the torque limit again. but otherwise its great, just listen for the beeps and you hit the set point.
1 - 20 of 21 Posts
