1 - 20 of 31 Posts
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: 9gen
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid only for the lower 48 states.
That's pretty cool! I like it :)
Discussion Starter · #6 ·
I didn't see any info on what type of warantee it has
Yes. Alien Prime is right. Our warranty is industry standard: 1 year from date of purchase, 90 days for calibration. Our repair / calibration facility is located in Chicago in case anything does need to be done to the wrench.
BLMW
Are additional fittings on these wrenches available as well, aside from what it shows it comes with?
Discussion Starter · #8 ·
By additional fittings, do you mean adapters? If so, we do not sell any. Put you can use any standard adapter (i.e. 1/2" to 3/8") and it would work fine as long as it did not increase the length of the wrench.
BLMW
That's great so it's a standard fitting, means you can use it will add your existing sockets :D
This is cool. I have similar one. Prevents from scratching your rims and those expensive lug nuts.
yeh my buddy broke some lugs because he didn't use a torch wrench and didn't know how tight he was going.... he was also way too strong to put the bolts on hahahah
1 - 20 of 31 Posts
