1 - 8 of 8 Posts
Resonator bypass with minimal heat soak. This draws in air coming in from the gap of the hood, and most importantly it's above radiator.
Many if not most CAI's get their air from the same place - above and to the right of the radiator.
1. Unplug #16 in the picture below.
2. Flip #16 upside down, and put the top part back into flexible rubbery hose going to the air box.
3. Then, shove the other end down under the sheet metal next to the battery. The pipe is flexible and it might require some force, but be careful since there's 2 wires directly below the sheet metal.
Hood stand thing won't fit back in the holder, so you will have to stick it next to the battery as well. It's quite secure there, won't move around.
View attachment 76618 View attachment 76626
Yes, what does this do? Any more power or better response at all? Or just noise?
Hey everyone is there anything i can replace the #16 part? Like an aluminum tubing? If yes where do you think i can buy it?
Sorry, car noob here. :)
1 - 8 of 8 Posts
