1 - 20 of 21 Posts
DIY: Genuine Modulo Sports Pedals - Manual Transmission
Installation of automatic transmission pedals may follow this DIY as the process includes similar steps.
Difficulty: 1/10 - Time: ~20 minutes
Before:
After:
Required parts (pictured below):
One (1) Modulo Sports clutch pedal cover
One (1) Modulo Sports brake pedal cover
Note: The brake and clutch pedal cover are the same size.
Six (6) 1/8” rivets
One (1) Modulo Sports gas pedal cover
Six (6) 3/32” rivets
Three (3) metal bars
Six (6) washers
Yes I realize one of the 1/8” rivets is mixed in with the 3/32” rivets.
Required tools (pictured below):
Drill
7/64” drill bit
Rivet tool
I recommend spending the extra few dollars on a good rivet tool. After the first pedal I had already broken my rivet tool and ended up finding a heavy-duty rivet tool for the same price.
Installation process:
Step 1:
Remove both the brake and clutch pedal rubber covers; discard.
Notice three (3) holes are already pre-drilled in each pedal.
Step 2:
Clean off both the brake and clutch pedal in order to remove any debris.
Step 3:
Remove each rubber cover from the Modulo Sports brake and clutch pedal.
[/URL][/IMG]
Place one (1) rubber cover over both the brake and clutch pedal.
Place one (1) metal cover over both the brake and clutch pedal rubber covers
Step 4:
Using the rivet tool, install each 1/8” rivet into each of the three (3) holes on both the brake and clutch pedal.
Step 5:
Once the brake and clutch pedals have been securely installed, place the Modulo Sports gas pedal cover over the existing gas pedal. Using the drill along with the 7/64” drill bit, drill six holes as pictured below. Clean the existing gas pedal in order to remove any debris.
Step 6:
Using the rivet tool, install each 3/32” rivet into each of the six (6) holes previously drilled. In addition to using the six (6) 3/32” rivets, use the three (3) metal bars and slide them in the available open space on the left side of the existing gas pedal under each row of rivets. Note: I forgot to use the six (6) included washers, however the pedal itself is tightly sedure without them. When utilizing the washers, one (1) is placed onto one (1) 3/32" rivet which is then installed into the previously driled holes - repeat for the remaing five (5) rivets and washers.
Finished product:
NOTE: I AM NOT RESPONSIBLE FOR ANY DAMAGES OR MISTAKES. INSTALL AT YOUR OWN RISK.
Aluminium Member
Excellent DIY instructions.
Should serve the forum we'll.
Bluestar's winch!!
Approved Chris. I did not know that's how you did it.
Bluestar's winch!!
Looks real nice. I get complacent because I have the metal pedals in my Si. Didn't realize the stock pedals were so junky lookin'. That would have been one of my first mods.
Reactions: FB2Chris
Discussion Starter · #8 ·
Thanks. I'm happy with how they turned out. The two things I'm worried about is (1) them easily getting dirty, especially during the winter season and (2) the "Modulo" logo wearing off over time.
I know this was a while ago but for those who still wanna check this out the pictures don't work anymore. Just a heads up.
Discussion Starter · #15 ·
Sorry, I no longer have an account with the image host I used to upload the pictures. I also don't have the pictures on my computer any longer. The only place that has the pictures is the other 9th gen forum, but I'm not going to transfer them here as they have that forum's logo on them.
Discussion Starter · #16 ·
I'm going to get the pictures fixed on this shortly in the event they're needed.
pictures are broken
1 - 20 of 21 Posts
