1 - 4 of 4 Posts
I have a 2012 honda civic couple lx. I be switching my clusters with the si red ones. I was in need if someone has a DIY guide on how to take out the dash and remove the clusters. If anyone can help that will be appreciated.
I'm also interested in this for my 2013 EX so I can go on and clean them (while also doing some mods). As of now they look disgusting.
Are you aware that some of the minor instrumentation is different between the two models, and may not work in the other car? I would check it out before beginning the work or buying parts.
i was looking for a write up over the weekend but didn’t find anything is pretty simple and straight forward
1-pull the driver side air vent and disconnect the switch 3-4 pins
2- the panel underneath the steering wheel had 4 pins 2 on each side
3-the lil box underneath the radio has 2 screws (phillips) once u open it
4- the radio has 2 more screws in front then 2 8mm underneath inside the pocket you take off
5- only after the the rain is off u take out the front cover where the RPM CLUSTER GOES pine only
6- there are 3 screws underneath all that to take out the big panel (also phillips) the rest are 6-8 pins
i wish i took pics but i was too busy taking stuff off and focusing without breaking anything....
GOOD LUCK
*im not responsible for anyone breaking their stuff do it at your own risk!!!!!
1 - 4 of 4 Posts
