21 - 40 of 88 Posts
Armo how did you file down he 02 sensor?
Reactions: Arm0ged0n
October K24Z7 2012 ROTM Winner
New Official So Cal 9's Crew.
Thanks Armo. Also for the Q300 install did you notice any rattle Armo. Cause i just installed mine yesterday & it rattles. I see its hitting against a metal part under the car. What can it be?
Discussion Starter · #24 ·
Does the rattle starts at 6k RPM's? I have the same issue, I've checked for air leaks, checked for loose bolts, checked the gaskets and everything's seems fine. From what I hear is that the rattle sound is more like the intake and downpipe sucking more air in.
May have something to do with the downpipe,not sure.I've been over 7k a few times since mine was installed but haven't noticed any rattles.
I installed just the exhaust so far. & lets say there is a little bump u can sometimes here it. It gets pretty annoying and the exhaust rattles up & down hitting that metal piece, i also made sure the rubber pieces were on tight.
Awesome DIY, wish I would have read it when I did mine. The cowl was the most frustrating part for me. Did at my friends shop on of his racks ( very lucky to be friends with a guy that owns a shop and rack ). Of course way easier than on your back on with jackstands. I also had a rattle problem in my N1 after install. Went ahead and pushed in some of the heat shields, and then noticed the muffler has a little bracket that connects the hanger rods together for support. That little bracket rod was hitting the cars hangar and you could see where there was paint missing. So I cut the bracket and boom no more rattle. Sounds great.
I Like Grits
Discussion Starter · #29 ·
Can you take a pic of the place where the bracket used to be?
Hey armo just installed the Rv6 dp thanks for the write up! Would of taken a lot longer but only major problem was that o2sensor! We didn't have a grinder so we had to McGuire a socket but in the end we made it work lol.
I cut the crossbar / bracket thing between the 2 hangars. The crossbar was hitting the chassis hanger making it rattle. Q300 doesnt have that though.
Thanks! Can you take a pic of the part you cut off so i can do the same to mine. That damn rattle noise is getting annoying
I have only installed my invidia q300 exhaust & not my ultimate racing fownpipe yet. But my exhaust rattles sometimes. It bangs on something!
its getting pretty annoying. I think im going to have to order another rubber mount
What can i do to stop the banging then? Should i get another rubber exhaust mount from honda?
Armo,
Got my RV6 today. I have a quick question. Does the 02 sensor on the bottom go straight in the pipe or that defouler pipe that comes with it? I have a catted version
Thanks
Vanilla Ice is my hero!!!
Armo,
Thanks
The O2 sensor goes into the defouler. I also have the catted version.
21 - 40 of 88 Posts
