Thanks to all of the other threads that provided guidance!
Installed a JVC KW-NT50HDT in a 2012 LX.
Have to remove/pull out the trim around the tach first. Will need to unplug the connectors on the ECON and Hazard switches. Also, place some sort of protective cover or tape over the manual climate control.
There are two screws holding in the Aux port panel, then there are two bolts on the bottom of the radio that come out with I believe an 8mm nut driver.
Disconnect the four connectors on the radio. Again, this is the LX w/out premium.
Will only reuse two of the connectors, the other two will just be tucked away until someone figures out a way to convert an aftermarket HU video output to a signal that the mid can recognize.
- - Gray for power and speakers. Notice that the VSS is not present, since the car did not come with factory Navi.
- - Brown has connections for the aux jack. (will not need to cut or touch this connector to reuse the Aux port, see below)
- - GA connections.
- - Antenna (This is the second connector that will be used.)
This is the Honda factory trim and brackets, for their Navi unit.
Trim: 77250-TR0-A01ZA ($33)
Driver's side bracket: 77256-TR0-A00 ($15)
Passenger's side bracket: 77255-TR0-A00 ($15)
Tapping screws: 93913-14420 (Quantity 6, don't just grab six screws from the floor of your garage)
The double din radio opening on the factory trim is slightly oversized, so I picked up this kit to snag the trim ring.
I was told that this is the kit you buy if you have the Honda factory Navi and want to replace it with an aftermarket HU. (the gray spots on the back of the ring are where I removed some clips that were not needed and frankly in the way)
This is the connector that is required for the 2012 power and speakers.
Important: This is the antenna adapter.
Looks like this is a new style that started in 2012. I am providing this becuase I was bought and returned two other adapters that were wrong.
This is the font of the unit with the trim ring installed. Yes, the radio that I am installing has a detachable faceplate.
Here's a side view to show how I bolted it in. Used the bolts that came with the radio.
(can only attach 10 pics per post, to-be-continued) update: was able to add an 11th
- Was able to reuse the factory Aux port
- Able to use a factory Honda trim
- Did not locate/verify the VSS location and have decided to sideline worrying about it. The GPS antenna is doing an awesome job by itself and waiting to see how it performs when the tree leaves return.
- - GA connections.
