Well, this is a fairly simple DIY :)
There are only a few things you need :)
- VHT Red NightShade Tint
- Map Lens Left (34402-SDA-A21)
- Map Lens Right (34401-SDA-A21)
- Dome Lens (34253-S5A-305) (Pictured)
- Very clean spot to spray
In my case i did a total of 4 layers. After even the first two even coats, it looks very covered, but if you let it dry and hold it up to the light you may get some areas that are not stained as well as others, or some cracks that you miss.
Always better to put more light coats then less heavy coats :)
Reactions: EvanChrisBrianScott
Looks clean! Personal preference I guess. I personally don't like any other color besides white for interior light :p
It will be brighter than having clear lenses and putting red LED :p
That's what I did at first, now, it'll be wayyy better :)
