Ok so.. I order all the pieces to install my double din avh 2300... but i couldnt wait so i just went out to the car for a little practice run...heres a list of all the things I got to install my radio..also replacing my grill so thats on there too(the stuff in red is for the radio...other stuff is the for the grill...
Order Details
Product NumberDescriptionQuantityUnit PriceTotal Price
93913-14420SCREW, TAPPING (4X16) (PO)4$0.34
90666-SD4-003CLIP, FITTING1$1.93
90133-SM4-003BOLT-WASHER (5X16)
90666-SDA-A01CLIP, SNAP FITTING (PO)(NATURAL)1$0.30$0.30
71103-TR7-A00DUCT, FR. BUMPER (UPPER)1$6.83
71121-TR7-A01BASE, FR. GRILLE1$93.31
77250-TR0-A01ZAPANEL ASSY., CENTER *NH809L*
77255-TR0-A00BRACKET, RADIO (PASSENGER SIDE)
77256-TR0-A00BRACKET, RADIO (DRIVER SIDE)1$10.55
total was 147$
Before starting..put tape in front of your heater controls and on the panels all the way down to your shifter... it will prevent from scratches while you work.. trust me.. FOR THE RADIO... its a 2008 Honda Accord Harness..make sure you wire your radio harness to the accord harness before you go take the dash apart.itll make things run smoother....
I stripped no wires, nor did i splice into anything to make my radio work! its plug and play..all wiring is done from the aftermarket radio to the accord harness..
1 .So pretty much there is two screws on top of the cigarette lighter thing..(regular phillips)... once you take those off.. remove the plastic piece that houses the cigarette lighter and aux input... pull on it softly make sure not to yank to far as the cables are connected on the backside...(Pic 1,2)
2. After removing the cables from the back of the cigarette lighter and aux.. there are two more screws which you will find under the actual radio...this are a little tougher to remove as its at an awkward angle.. but not too difficult... after you remove those 2 screws ..thats it!!! the radio is loose.. I couldnt believe how simple it was...(Same Pic 2)
3. Now Go to your dash and place your hand like behind the steering wheel over the top.. youll notice there is a nice gap there that will let you take a firm grip of the dash piece..pull slowlyy.. the dash piece is all clips..(pic 3)
4.there are TWO connectors on the dash piece...one on the far left right behind the ECON button ( pic4) and then the other is on the opposite side on the right...same position... (pic5).. after you remove those two you can remove the dash piece and place it somewhere safe..
5. This will now expose the left side of the radio... again softly pull either from the top left of the radio or the bottom left... the radio has about 7 clips so be gentle.. and be patient!!! you dont want to break any clips anywhere!.. (PIC 5 & 6)
6. Plug your harness in and there you go... make sure your car is off while you do all this... I was able to do this without blowing any fuses.. my imid still functions perfectly fine..(Pic 7 , 8 ,9)
I will be updating when i receive the rest of the parts and finally fully install radio... any questions let me know.. glad to help
