What gear do you park in?
  • 1st
    Votes: 26 41.3%
  • 2nd
    Votes: 0 0.0%
  • 3rd
    Votes: 2 3.2%
  • 4th
    Votes: 0 0.0%
  • 5th
    Votes: 0 0.0%
  • 6th
    Votes: 0 0.0%
  • Reverse
    Votes: 6 9.5%
  • Neutral
    Votes: 26 41.3%
  • Don't give a rats fat nipple
    Votes: 3 4.8%
1 - 20 of 58 Posts
Park, place in neutral, engage emergency brake, turn off engine, place car in gear, or just the use of emergency brake, could also depend if on incline or not.:eek3dancesmiley:
Bluestar's winch!!
I stop, put into 1, put on e-brake, shut off, disengage clutch.
Can leave it out of gear if on a flat but I've seen my bros Prelude drive itself across a parking lot, even when on a relatively flat surface.
I do exactly the same procedure.
+1 to that
Oh boy. I leave my car out of gear and pull e brake. I better start practicing leaving it in gear, but I know people who do it both ways and have never had any issues.
Sorry to hear about those kplayground emblems I would pissed!!!! Im glad I didn't order from them. $100 and then to have them not show up and they are ignoring emails. Poor customer service.
Reverse is a bit better because its geared so low that it will create more resistance than first
Always put into gear. This is especially true when you have a rear DISC as an e-brake.
Actually I have a very steep driveway and just went out there and tested the reverse gear theory and 1st gear definately holds the strongest. 6th gear and reverse both spun the engine over. First did not.
oh crap..i never put it into gear when i park it. TIL it is better to put your car into gear when parking with a manual.
You're a fool if you don't put it in gear with the parking brake up.
My second 2012 Si was on a SLIGHT incline, and I ran into my office to grab something with it idling, with just the parking brake on. Good thing I turned around to take a look at the gorgeous car, because it was rolling backward. If I hadn't looked, it would have rolled into several other parked cars.
And the brake was definitely fully engaged. I will never take a chance again. Never had a car do that before - leave it to my luck with Hondas.
When I park the car in the driveway at home I normally just do the e-brake especially when im on morning shift cant even remember how many times I poped the clutch forgetting it was still in gear when starting the car.
1 - 20 of 58 Posts
