1 - 5 of 5 Posts
This morning I got into my car to go to work and noticed the button/switch that controls the driver's window was not working. The button/switch that controls the passenger side's window was working. Also, the Window Lock switch to lock the passenger's window was not working.
My car has never had any sort of electrical failure or other issue yet, and the windows were working fine only hours before I noticed this. There is no 'click' sound when I push the button, it sounds as if it would if the car was totally off. The buttons do nothing.
After looking online I found the following 'solution':
1. Turn the ignition off.
2. Put the intermittent wiper speed dial in the middle position.
3. Turn the ignition on.
This 'resets the brain' and should supposedly fix most power window issues but did not work for me because I have an LX, and the LX model does not have an intermittent wiper speed control.
Any suggestions? I literally was riding with my windows down last night, no problems, and today they don't work. No clue what could be happening. Any potential solutions?
Thanks,
B.
time to go to the stealership...:unsure:
That is weird. Def take that in, sounds like pins are backward in the harness.
1 - 5 of 5 Posts
