so I was doing a pull last week and going from 3rd to 4th the shifter got hung up a lil bit, not quite a mishift but went in after I let off the car turned the CEL on. got home checked hondata and I get a p0339 code..
replaced the sensor with one from O'Reillys and some code.. replaced it with one from Honda oem same code..
I was told I needed to relearn the sensor to the car is this true.. was also told it could be a stretched chain..
sounds like its not the ckp sensor since a bad sensor code is P0335.
P0339 (ckp intermittent circuit interruption) is likely, bad ground, connector or the PCM.
changing both pulse plates timing chain and tensioner this weekend hopefully this does something.. I do have the previous tune
