im required to pass OBD every year. I have the CT supercharger, no cats. and every other bolt on imaginable lol. I have passed twice so far. Yes you can activate your secondary O2. its not going to hurt the car. ..............but dont be a complete moron and test the limits of this. Just drive like a human being. Dont activate it the day before inspection, your car needs more time to set readiness. Your EVAP tests will only run when the fuel is 3/4 tank or less.
Youll need a defouler in the secondary o2 sensor as well.
so make sure all the emissions things are enabled, then drive the car. Its going to take at least 3 days of driving cycles. meaning starting with a cold car everytime. so drive around, park for the night, drive again the next day. Those are complete cycles. And it takes a couple for the EVAP to set.
You can check the readiness with flashpro by having it plugged in to the car and a laptop while running, go to ONLINE>OBDII DIAGNOSTICS. and youll see readiness monitors.
or a quick way to see if ALL of them are set and good to go. turn your key to the ON position, wait for the check engine light to go out, then a few seconds later see if the check engine light starts flashing. If it does, they are NOT set. If it doesnt you are good to go!
Problem i face now is my clutch and flywheel i just installed, it requires misfire to be turned off. I need to try to get the dealer to relearn my crank sensor pattern. See if that works. as it sits now, it wont pass next year unless i install the factory clutch
